Bosch EcoLogixx 7 – no heat?
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch EcoLogixx 7 – no heat?
  • #78010
    faxfan2002
    I have a new Bosch Ecologixx 7 – WTW86562GB (with heat pump). So I put a load in and get came out more or less exactly the same as I put in from the washing machine. The machine doesn’t seem to be generating any heat what so ever.
    Had a search on here and found the reset switch trick but I couldn’t find one on mine? Any ideas anyone?
    #404174
    Re: Bosch EcoLogixx 7 – no heat?
    Try cleaning the stainless steel moisture sensors in the drum. If the the fault persists call the Bosch service department.
