Bosch ENR HBN430550b/02
  • #50420
    PGS
    Has anyone got a parts breakdown for above. Cheers Paul.
    #304777
    lee8
    Re: Bosch ENR HBN430550b/02
    Here you go,
    Set Filter
    0115 014254 Spring 020 4,20 EUR 10 Info: Add to shopping basket Documents for Spare part 014254
    0301 057874 Lamp 240V-40W 020 4,20 EUR 1 Info: Add to shopping basket Documents for Spare part 057874
    0313 068492 Socket 007 1,20 EUR 2 Info: Add to shopping basket
    0508 084500 Cover Netzdeckel Cover,backside 010 1,70 EUR 1 Info: Add to shopping basket
    0031 150347 600243 Screw-set 050 11,20 EUR 1 Info: Add to shopping basket
    0302 176141 647309 Lens 020 4,20 EUR 1 Info: Add to shopping basket
    0215 187357 Resistor-vdr 020 4,20 EUR 1 Info: Add to shopping basket
    0402 419864 603830 Base rechts 090 17,90 EUR 1 Info: Add to shopping basket
    0401 419865 603830 Base links 090 17,90 EUR 1 Info: Add to shopping basket
    0134 420601 Coupling Connection piece oven thermostat ==>
    switch handle holder 002 0,50 EUR 1 Info: Add to shopping basket
    0135 420630 424534 Support 035 8,00 EUR 1 Info: Add to shopping basket
    0604 420673 644828 Socket 095 18,60 EUR 1 Info: Add to shopping basket Documents for Spare part 420673
    0404 420735 Spacer Front glas window, clacking protector 007 1,20 EUR 4 Info: Add to shopping basket
    0412 420736 612595 Panel rechts 015 3,00 EUR 1 Info: Add to shopping basket
    0411 420737 612596 Panel links 015 3,00 EUR 1 Info: Add to shopping basket
    0214 420753 Limiter-temperature Brandschutz 017 3,70 EUR 1 Info: Add to shopping basket
    0312 420756 423656 Seal-door 060 13,30 EUR 1 Info: Add to shopping basket
    0304 420760 Filtering jug Oberteil vapour extractor 027 6,20 EUR 1 Info: Add to shopping basket
    0209 420761 Safety pan retainer Tropfschale Drip shelf vapour duct 004 0,70 EUR 1 Info: Add to shopping basket
    0300 420775 Lamp kompl. mit Gehaeuse 065 14,10 EUR 1 Info: Add to shopping basket Documents for Spare part 420775
    0303 420825 Ring auf Glaslinse 020 4,20 EUR 1 Info: Add to shopping basket
    0131 420850 Holder 004 0,70 EUR 1 Info: Add to shopping basket
    0150 420944 Cable harness 030 6,80 EUR 1 Info: Add to shopping basket
    0101 421428 Ring 002 0,50 EUR 2 Info: Add to shopping basket
    0110 421445 Knob 055 12,40 EUR 1 Info: Add to shopping basket
    0116 421448 Guide 002 0,50 EUR 1 Info: Add to shopping basket
    0102 421453 Push button set 165 28,80 EUR 1 Info: Add to shopping basket Documents for Spare part 421453
    0151 421458 Cable harness 017 3,70 EUR 1 Info: Add to shopping basket
    0123 421727 Support SWITCH HANDLE HOLDER 013 2,30 EUR 1 Info: Add to shopping basket
    0213 421793 Limiter-temperature Luefterclick 020 4,20 EUR 1 Info: Add to shopping basket
    0133 421811 Holder Notfallbefes./UHR 017 3,70 EUR 1 Info: Add to shopping basket
    0407 421950 Bracket 007 1,20 EUR 1 Info: Add to shopping basket
    0137 422340 Bracket auf Traeger gesteckt 002 0,50 EUR 2 Info: Add to shopping basket
    0601 434175 440579 Grid 846 26,81 EUR 1 Info: Add to shopping basket
    0600 434178 Broil pan 464,6 x 375 x 37 mm 841 22,07 EUR 1 Info: Add to shopping basket
    0605 434605 Grid 080 15,90 EUR 1 Info: Add to shopping basket
    0212 434801 667344 Air channel 025 5,40 EUR 1 Info: Add to shopping basket
    0413 434807 678268 Panel-aeration 175 32,90 EUR 1 Info: Add to shopping basket
    0210 434832 Air channel exhaust Wrasenkanal Oberteil Vapour duct bottom 010 1,70 EUR 1 Info: Add to shopping basket
    0314 434859 Strip PBT VZF39179(IC-grey) at the bottom 010 1,70 EUR 1 Info: Add to shopping basket
    0606 435152 663344 Liner-catalytic links 210 45,20 EUR 1 Info: Add to shopping basket
    0607 435153 663345 Liner-catalytic rechts 190 35,50 EUR 1 Info: Add to shopping basket
    0602 435794 Grid Einlegerost 846 26,81 EUR 1 Info: Add to shopping basket
    0603 435795 Handle 070 14,90 EUR 1 Info: Add to shopping basket
    0400 435838 Handle-door 270 75,00 EUR 1 Info: Add to shopping basket
    0100 435845 Panel-facia 285 83,50 EUR 1 Info: Add to shopping basket
    0311 443341 Heater-ring 175 32,90 EUR 1 Info: Add to shopping basket
    0507 470726 Case-rear part Main terminal cover included 085 16,90 EUR 1 Info: Add to shopping basket
    0500 470729 680092 Panel side links 065 14,10 EUR 1 Info: Add to shopping basket
    0501 470730 680091 Panel side rechts 065 14,10 EUR 1 Info: Add to shopping basket
    0310 470763 Heater-bottom 200 40,00 EUR 1 Info: Add to shopping basket
    0205 470846 680061 Sheet Zwischenw. hinten PARTITION/BACK PANEL 050 11,20 EUR 1 Info: Add to shopping basket
    0406 470864 Intermediate panel Zwischenscheibe coated 210 45,20 EUR 1 Info: Add to shopping basket
    0410 470865 Inner glass Vollglasinnenscheibe Drop-down door oven 255 65,00 EUR 1 Info: Add to shopping basket
    0208 470881 680199 Sheet Lueftergrundblech FAN SUPPORTING PLATE 055 12,40 EUR 1 Info: Add to shopping basket
    0504 470883 479675 Case-bottom Grundplatte 045 10,10 EUR 1 Info: Add to shopping basket
    0206 470884 479676 Housing part Zwischenb. unten 040 9,00 EUR 1 Info: Add to shopping basket
    0506 470885 Cover oben 080 15,90 EUR 1 Info: Add to shopping basket
    0306 470886 Insulating part Set included jacket-, ceiling-,
    back panel- and base insulation 270 75,00 EUR 1 Info: Add to shopping basket
    0308 470970 Heater-top 215 47,20 EUR 1 Info: Add to shopping basket
    0315 470972 Catalytic ceiling 265 71,20 EUR 1 Info: Add to shopping basket
    0403 471355 Glass front panel 313 117,00 EUR 1 Info: Add to shopping basket
    0201 482980 496955 Fan blade tempered fan wheel 085 16,90 EUR 1 Info: Add to shopping basket
    0200 490541 Motor-fan 230 54,60 EUR 1 Info: Add to shopping basket
    0136 490624 Regulator Oven thermostat 160 27,60 EUR 1 Info: Add to shopping basket
    0503 490768 Holder rechts hinge holder right 020 4,20 EUR 1 Info: Add to shopping basket
    0502 490769 Holder links hinge holder left 020 4,20 EUR 1 Info: Add to shopping basket
    0307 490772 Holder oven thermostat 010 1,70 EUR 1 Info: Add to shopping basket
    0211 490780 Motor-fan 205 42,60 EUR 1 Info: Add to shopping basket
    0132 491227 649644 Clock 240 59,80 EUR 1 Info: Add to shopping basket
    0130 491450 Switch-selector 172 31,20 EUR 1 Info: Add to shopping basket
    0207 491686 Terminal Netzklemme 095 18,60 EUR 1 Info: Add to shopping basket
    0405 499345 Hinge-door 9,1 NM 130° 035 8,00 EUR 1 Info: Add to shopping basket
    0414 519252 Sticker replacement identification plate,for the additional marking,for Bosch
    ,Siemens,Neff and brand neutral,4 pieces with ever 7 stickers 030 6,80 EUR 4 Info: Add to shopping basket
    0021 586500 Installation instructions de,en,fr,it,nl,da,sv,no,fi,es,pt,el,cs, 027 6,20 EUR 1 Info: Add to shopping basket
    0001 587476 Instruction manual en 027 6,20 EUR 1 Info: Add to shopping basket
    0199 649693 Fixing kit Mounting set for hot-air guide plate 080 15,90 EUR 1 Info: Add to shopping basket Documents for Spare part 649693
    0203 668613 Hot-air guide plate Catalytic enamel
    #304778
    all bosch diags and part breadown avail online
    http://shop.bshappliancecare.com/
    great service very useful
    PGS
    Thanks Guys.
