Bosch Error 9 – Cause? Worth Repairing? Help!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Error 9 – Cause? Worth Repairing? Help!
  • #92775
    dishwasherdespair83
    Hi I have a Bosch Aquastar 6.0L with error 9 code after the wash is complete. The water is always cold.
    How can I cheaply find out the precise cause? Is it worth repairing? Also is it easy to prove this was a manufacturing defect? We took appropriate steps for hard water.
    I have a multi-meter but not sure what to test. The repair must be carried out by a repair person and not DIY.
    #452130
    Re: Bosch Error 9 – Cause? Worth Repairing? Help!
    The heater (attached to the main pump motor) needs replacing. 🙁
    Have you been putting salt in the water softener regularly?
    #452131
    dishwasherdespair83
    Hi Martin,
    Thanks for getting back to me quickly.
    Absolutely been putting salt in the dishwasher regularly. Is it is possible that it could be the thermostat/circuit board/heat pump rather than the heating element?
    The dishwasher is less than 3 years old.
    #452132
    Can’t rule anything out without checking of course but heater unit THE most likely culprit.
    #452133
    dishwasherdespair83
    Ok good to know, thank you.
    Looks like it would be something like up to £160 parts and labour according to the which website. Might be best just to buy a new dishwasher in that case. Not prepared to DIY when water and electronics are involved.
    We live in a hard water area. Error 9 seems to be a common complaint as well as error 15. Might be grounds for a claim of defective manufacturing with the retailer since some of the dishwashers are failing after only 2 or 3 years and this apparently does not seem linked to failing to use salt in some cases.
    #452134
    don
    Can you post up the ENR and FD no. please. Usually found just left of the door catch etched into the metal. Not easy to spot sometimes, a torch may help.
    Don
