dryer ntc failure, unplug machine from mains,lid off look down to where dryer duct meets door gasket, on the left see you will see it pushed into rubber bellows with 2 wires coming out hope this helps smartin
I’m a hotpoint engineer, and this sort of failure is usually because the drier fan is jammed, or the user has stopped the drier mid cycle. Is there a common factor for this on the bosch machine, or as with the hotpoint could it be a board fault.
