Bosch error code help?
  • #29469
    Got a customer with a Bosch WFF2000GB/01 with an intermittent fault. When is stops the ‘start’ led and the ‘spin’ led are flashing? 😕
    #223317
    Turbo
    Re: Bosch error code help?
    Sounds like the pump or something stuck in the pump to me.
    Could be a blocked pressure system if the machine is draining the water off ok but not spinning.
    Graham
    #223318
    Redflame
    Pump or Blockage or Valves (Double one) – Should be one these – Just not sure which as been a while now
    #223319
    Yes it was the double valve at fault (coil open circuit)….Cheers! 🙂
