Hi the bosch dw enr sgs45e68gb/64 fills and pumps intermittantly
main pump kicks in with little water no error codes , stops filling and pumping but water level is to low ?
prima wd lpr720 customer says it takes about 2 hours to dry a load it used to take 1 hour ? heater ok and getting hot fan ok drain pump ok ??????
The dishwasher fault is prob the impellor jug ( flow rate meter ) If it fills/drains almost constantly from start up , then thats 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} the fault – part no: 424099
Oh , and its always worth checking the ribbed fill hose between the pressure chamber and sump for blockages/gunge build up
