Re: Bosch excell help required
Penguin45 wrote:Machine is probably underfilling. There is a corrugated hose in the front left corner under the machine which needs to be stripped out and cleaned to allow full filling.
Power off if you wish to investigate this yourself, or click the link below for a UKW engineer in your area.
I have looked where you say and hose is not accesable.I doubt this is blocked as we are in the soft water part of the country and the inlet filter is not blocked.Machine fills OK with water but when it wishes to run the program it just clunks as it tries to either draw more water or spin the washers, and at the same time drains the water.Timer does not count down! 😕
