The pump is on the RHS as you look at the machine. It can be a bit awkward to remove if you havn’t done the job before.
If its saying ’empty container’ , there are a couple of possible’s . I’d first be checking the hose/connection at the rear of the area that the water container slides into. This is prone to blocking with fluff.
Then its the drain pump/sump area that may need to be cleaned out .
went to this drain pipe was blocked at plastic bit thats goes into try sorted. now runs but no heat,heater cut out at back not triped. no power to heater. what you think lads pcb? and end and anti crease lites comes on after bowt 10 secs
It’s a sensor dryer and needs testing with a couple of damp towels in the drum otherwise the heat cuts off after 10 seconds. It cannot be tested without putting something in the drum! 😉
