Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch Exxcel 12 place dishwasher programme failure
- This topic has 19 replies, 6 voices, and was last updated 19 years, 1 month ago by
vatinspector.
February 15, 2007 at 5:01 pm #25079
vatinspector
ParticipantWhen I select any of the three prograsmmes, half way through the clock changes to an even longer total running time than that originally selected. If it does reach one minute it is still washing, instead of drying, and again resets itself to a longer time, in the past it has eventually stopped although at the time of typing this time it has gone from one minute on three occassins. Any ideas please. Would a failed heater have these symptoms because we have had problems with heaters in the recent past?
February 15, 2007 at 5:21 pm #204409Martin
ParticipantRe: Bosch Exxcel 12 place dishwasher programme failure
vatinspector wrote:Would a failed heater have these symptoms because we have had problems with heaters in the recent past?
VAT inspector eh? 😉
Does your machine heat the water at any stage?
Are you regularly using salt?
Does it work OK on the ‘non-auto- programmes?
Have you tried using a dishwasher cleaner?
What is the full E.Nr of the machine (model no)?February 15, 2007 at 7:33 pm #204410vatinspector
ParticipantHi Martin,
Thank you very much for your reply, I am a very nice VAT inspector!
The interior was faintly warm when I opened the door, but that may have been the drying cycle rather than the water being heated.
I have never used salt becuase the instructions recommend using 3 in 1 tablets, so that is what I have used!
It doesn’t work on any programme, we ran it with dishwasher cleaner on a non auto cycle and it did just the same thing, got to 1 minute and then went to 16, got to 1 and back again, and so on. In the end we switched it off! It was still washing even on 1 minute when it should have been drying by then.
The number is SGS45E08GB/56
February 15, 2007 at 8:14 pm #204411urbantiger
Either the heater has gone open circuit or more likely the pipe between the side chamber and the sump or the level chamber is blocked so that it runs without enough water in -level switch is made early because of the blockage and without enough water it won’t heat properly
hope this helpsFebruary 15, 2007 at 8:44 pm #204412vatinspector
ParticipantThanks urbantiger, any idea how I check the pipe for blockages? It may be the heater, but that was replaced 10 months ago under warranty, I guess that means they should replace it for free if it has gone again!
February 15, 2007 at 9:06 pm #204413Penguin45
Under the tub, front left corner, there is a ribbed hose which chokes up and causes the machine to under-fill. Outer door off, kick panel off, lower cover plate off and all will be revealed.
Power off, of course.
Pwenguin45.February 15, 2007 at 10:15 pm #204414Trilobite
Participantvatinspector wrote:Thank you very much for your reply, I am a very nice VAT inspector!
A likely story! :rotfl:
February 16, 2007 at 12:40 am #204415Penguin45
Ah, Tribbles…….. we’d been so neutral up ’til now……….
February 16, 2007 at 12:56 am #204416gegsy
Yea tribbles :snigger: and they were so brave using that name aswell 😛
February 16, 2007 at 1:05 am #204417Penguin45
gegsy wrote:tribbles
Didn’t they get beamed off the ship?
:p45:
February 16, 2007 at 1:11 am #204418gegsy
Sure did, Lt. Nyota Uhura
February 16, 2007 at 1:15 am #204419Penguin45
ParticipantFebruary 16, 2007 at 8:19 am #204420vatinspector
ParticipantOk you guys but Kirk was on the fiddle with his Vulcan Vat – how do I get the door off? Please guys.
February 16, 2007 at 8:51 am #204421Martin
Participantvatinspector wrote: how do I get the door off? Please guys.
Please do not take the door off!!!!!
Instead buy a set of these from Betterware : –
Take the filters out of the tub and use the smaller of the 3 brushes (from the left) to clear the inlet pipe situated in the 7 o’clock position! 😉Once the gunge is cleared operate the machine with a dishwasher cleaner and always keep that salt container topped up! 8)
February 16, 2007 at 9:04 am #204422vatinspector
ParticipantHi Martin, gee thanks, we will do. now do we use salt plus the 3 in 1 or instead of. Incidentally we live in south London.
