Bosch Exxcel 1200 Express (WFX2467GB/01) – filter stuck!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Exxcel 1200 Express (WFX2467GB/01) – filter stuck!
  • #78213
    Carmodyjane
    I have a Bosch Exxcel 1200 Express and yesterday it decided that instead of spinning it would make a clanking, rattling noise. I turned off the power, removed the clothes and tried to check the filter. I say “tried” because the filter cover refused to fully turn or open. (I check/clean the filter on a roughly weekly basis).
    We have tried tilting the machine to dislodge whatever is wedging the filter shut, but have had no luck. My other half then used a pair of pliers to try to force the filter open and the net result of this brute force is that the filter lid now won’t turn even partially. (Sigh…men. I bet I would have had better luck trying to negotiate with the filter).
    Anyhow, we are now in a pickle of wondering whether it’s worthwhile (i.e. cheaper) to call a mechanic around or if we should buy a new washing machine. I’m on this forum to see if there is the remotest chance of another (i.e. cheaper) solution preferably one that doesn’t involve my other half using a sledgehammer or dynamite :eeek:.
    I’ve done my homework by reading the brilliantly informative help pages on this web site but none of them help me regarding a stubborn filter lid.
    All suggestions (bar handwashing in future) greatly appreciated.
    #404843
    Re: Bosch Exxcel 1200 Express (WFX2467GB/01) – filter stuck!
    The pump/filter unit can be easily accessed and sorted by a local independent. Going the DIY route you’ll first need to start by buying THIS
    Don’t be too hard on hubby and fear not your machine can be soon put right! 😀
    #404844
    Carmodyjane
    Thanks for your advice, Martin. Hubby had another go and freed his two shirt collar tabs (Ha ha! NOT my bra wires) that had stopped the drum from rotating. Bosch is fine and dandy.
