Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Exxcel 1200 S Express drum not rotating freely
- This topic has 8 replies, 2 voices, and was last updated 11 years, 3 months ago by
Onward.
January 6, 2015 at 12:55 am #83626
Onward
ParticipantHi All
Please can you help me? I noticed an unusual noise on the final cycle of a wash on the above machine. The wash was fine and a further wash was OK but the noise was there again. With the machine emptied I tried to turn the drum by hand and noticed it is not spinning freely. It is rotating but moves tightly and with a squeak. Could anyone tell me what could be wrong and how to investigate and rectify please?
Many thanks
January 6, 2015 at 4:56 am #423291Martin
ParticipantRe: Bosch Exxcel 1200 S Express drum not rotating freely
Sock caught between drum and tub?
January 6, 2015 at 11:16 am #423292Onward
Thanks Martin. Do you on this machine if the area is accessible to remove the object and how I get to it? Thanks
January 6, 2015 at 12:34 pm #423293Onward
Hi All. It seems the drum is binding against the door seal as when I pull the inner seal back the drum moves normally. I can’t see anything stuck in the drum and the door seal appears fine. Any ideas please? Could something be causing the inner drum to have moved forward towards the door seal? Is this a case of removing the back of the machine and seeing if it is possible to retrieve any object without trying to completely dismantling the outer tub from the drum, and then finally doing a full dismantle if I can’t? Many thanks in advance.
January 6, 2015 at 2:08 pm #423294Martin
It could be the drum shaft spigot has broken and the inner drum now rotates on an elliptical plane as a result. What is the full model number (ENR number) of the machine and what is the four digit FD number (FD????)
January 7, 2015 at 12:12 am #423295Onward
Hi, thanks for the reply. Numbers are E-NR: WAE2446SGB/12 FD8803. I’ve looked closer at the drum edge which is rotating against the door seal and the rotation has caused rubber to stick to the drum edge in places and there are tiny fragments of rubber on the drum edge. Any advice gratefully received.
January 7, 2015 at 5:10 am #423296Martin
In that case I refer you to my previous post as to the diagnosis.
January 7, 2015 at 10:25 am #423297Onward
Thanks Martin. From looking at the movement of the drum in relation to the outer tub through the holes and by rotating the drum by hand, the rotation appears normal, i.e. no noticeable elliptical type movement. Please can you explain how I would investigate this further? Thanks
January 7, 2015 at 2:19 pm #423298Martin
Onward wrote: Please can you explain how I would investigate this further? Thanks
Power unplugged, remove the belt then check again the orbital rotation of the drum. If the drum spigot is cracked the elliptical movement has only to be fractional in order for the drum to rub against the door rubber. An it will usually only strike one spot of the door seal each time.
Replacing the inner drum and bearings regarded as somewhat uneconomical. 🙁
