Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch exxcel 1400 express
- This topic has 28 replies, 7 voices, and was last updated 20 years, 2 months ago by
bongle.
February 3, 2006 at 10:29 am #163095
bongle
ParticipantRe: Bosch exxcel 1400 express
The dispenser jets arn’t clogged as with mine you can take the jet plate off and clean it and its spotless! ive scrubbed it with a tothbrush and cottonbuds. I dont know the model number where would i find this? i havnt got the instruction book either sorry i threw it.
February 3, 2006 at 10:35 am #163096Goatboy
It must be bad/no water pressure!
Martin wrote:Easy way to be sure is to NOT put any fabric conditioner in the compartment. Instead put a dry broken biscuit or similar in that compartment. Set it to “Rinse & Spin” then see what’s happened to the biscuit??
More tea vicar?
A nice simple test to see if you’ve got water. It could be a valve failure, but I suppect the machine is too young. We’d know if you could give us a ‘enr number’ from inside the door?
Help us, to help you!
February 3, 2006 at 11:19 am #163097Goatboy
Goatboy wrote:
Martin wrote:
Easy way to be sure is to NOT put any fabric conditioner in the compartment. Instead put a dry broken biscuit or similar in that compartment. Set it to “Rinse & Spin” then see what’s happened to the biscuit??😳 I’ve just realised that I’ve misguided you there 😳
For yours, put something in the main wash compartment (on the left) on put it on wash, not rinse + spin.
February 3, 2006 at 11:42 am #163098Martin
I see you’ve had a haircut GB…..?
February 3, 2006 at 12:25 pm #163099bongle
Ok heres the number from the door……….
WFX2867GB/01 FD8404 600228Hope this is the right one? thanks x
February 3, 2006 at 12:34 pm #163100Martin
bongle wrote:Hope this is the right one? thanks x
Yes thanks, it indicates to me that as your machine does not have a flow sensor, your problem is water pressure (pretty sure)!
Now I would suggest you check the water inlet valve filter (remove cold hose to access) as the fine mesh may be silted up?
As your machine is under 2 years old it is still under warranty and you could get Bosch in to take a look, though I doubt there isn’t any fault with the dispenser or valve though?
bongle wrote: i havnt got the instruction book either sorry i threw it.
Oh dear! Its a vital reference book for users when things go wrong and stuff 😥
February 3, 2006 at 12:37 pm #163101bongle
To check that would i have to pull the machine fully out or not?
February 3, 2006 at 12:38 pm #163102Martin
Its at the back (as shown in ‘user booklet’) 😉
February 3, 2006 at 12:41 pm #163103bongle
Sorry i havnt got the booklet you see, ill have a look in a minute and im looking for mesh right?
February 3, 2006 at 12:56 pm #163104Goatboy
bongle wrote:…im looking for mesh right?
Yah! In the pipe, where it screws onto the machine.
You know to turn off the water first, right?
Martin wrote:I see you’ve had a haircut GB…..?
I looked in the mirror the other day, and realised I look like Beaker! 😕
February 3, 2006 at 1:04 pm #163105bongle
OOO good job you said i wouldnt of turned it off, right im gonna go now and investigate………erm look to turn the water off first of course! thanks for your help x
February 3, 2006 at 1:06 pm #163106Martin
Goatboy wrote:I looked in the mirror the other day, and realised I look like Beaker! 😕
How do you get it to stick up like that…wax or axle grease?
February 3, 2006 at 1:21 pm #163107Goatboy
bongle wrote:OOO good job you said i wouldnt of turned it off…
I get my hair to stick up like that by looking at Herloni spare parts price rises! 😉
February 4, 2006 at 5:21 pm #163108bongle
now I would suggest you check the water inlet valve filter (remove cold hose to access) as the fine mesh may be silted up?
Hiya tried the above and everything was ok still no luck i have to keep adding extra water to the drawer so they dissolve! thanks anyway guys x -
