Bosch exxcel 1400 express
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch exxcel 1400 express
Viewing 15 posts - 1 through 15 (of 29 total)
  • #15318
    bongle
    Hiya i have had this machine now for about a year and have not been able to fault it in any way…….until the last few days ive noticed in the drawer that the tablets are not being taken through fully and loads are being left behind in the drawer.
    I have cleaned it out spotless and also cleaned the top but still the same, it is however taking the fabric conditioner with no problems. Hope someone can help as this is driving me mad!!!! 👿
    #163081
    Dave_Conway
    Re: Bosch exxcel 1400 express
    Have you changed to a different tablet recently ?
    Some dissolve much more efficiently than others 🙂
    It may be worth checking the upper part again and give it a good scrub with an old toothbrush around all the small holes. Other than that, low water pressure on the hot side may be causing it.
    #163082
    bongle
    Yes ive changed the tablets 3 times now and it still happens, i have just cleaned it again with buds and a old toothbrush, i did notice that the top part does pull away and click back into place so thats been cleaned as well now!
    I looked when the draw was out and the water is going through all the holes perfectly so i dont know what to do other than use the tablets you put in the drum?
    I am putting them in the correct part arnt i? ive got 3 section to the draw, i use the first for tablets-middle for softner- whats the other one for?
    thanks in advance x 🙄
    #163083
    Dave_Conway
    Yes, left hand for powder and tablets, this is where the hot water inlet is directed and I think is the problem (as first reply).
    Check the hot water pressure/flow to the machine 🙂
    #163084
    gegsy
    You will find the Aeriel tablest will give the best wash result and will dissolve very efficiently compared to some other brands.
    Ariel tablets are the ONLY tablets that can be used in the drawer, any others will not dissolve and will require the use of a net/bag in the drum.
    bongle
    Mine fills with cold water first not hot? is this correct
    #163087
    gegsy
    Depends on wash selected. If you choose a low temp then yes it will put cold in first to avoid damaging garments; if you choose a hot wash it will fill with hot.
    The new excells are a cold fill only.
    Hope that helps.
    PS The aeriel tablets will dissolve efficiently in hot or cold water 😉
    #163088
    bongle wrote:Mine fills with cold water first not hot? is this correct
    Absolutely correct, in fact (though you didn’t give us the model number of your machine) it probably doesn’t have a hot supply connected to it?
    Ariel Tablets are certain to solve the problem for you by the way 😉
    #163089
    bongle
    No it hasnt got a hot water connected to it dont know why…….but anyway ill go and get some new tablets now and see if they work thanks for all your help as well x
    #163090
    kwatt wrote:Ariel tablets are the ONLY tablets that can be used in the drawer, any others will not dissolve and will require the use of a net/bag in the drum.
    I used Daz tablets in the drawer for years without problems, in a bungalow with moderate hot water pressure. Now use Ariel for slightly better wash performance. 🙂
    #163091
    gegsy
    Should try dissolving persil tablets, more chance of eroding a diamond 😆
    bongle
    Ive used to ariel ones and they are still all stuck in the drawer!!!! gr this is driving me mad, thanks anyway guys x
    #163093
    bongle wrote:Ive used to ariel ones and they are still all stuck in the drawer!!!!
    I’m very puzzled by this 😕
    I wish you would let us have the model number of your machine(Enr number) as I would love to solve this problem for you 🙂
    #163094
    If the Ariel tabs are not disolving then it can only really be a water pressure problem or the dispenser jets are clogged. Happens a lot in “peaty” areas up here.
