When the above machine was working this morning it suddenly began to vibrate and move about. On first inspection door seal had been badly damaged ie out of shape/twisted. The other problem is the water won’t drain. I have tried draining through the drain tube and removed pump filter, nothing. Can you point me in the right direction.
Thanks, mod no is WFX145SGB. Can you give me a point in the right direction how to fix. Not a washmachine engineer but I fix Worc Bosch boilers for a living.
