Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Exxcel 1400 Spin cycle problem
- This topic has 6 replies, 3 voices, and was last updated 18 years, 6 months ago by
mikejphillips.
September 24, 2007 at 8:43 am #30774
mikejphillips
ParticipantNew – member and thanks to all for this forum. I have successfully replaced the main motor brushes (following the advice here) on this machine which is about 5 yrs old.
Problem now is that the spin cycle (which was ok before the motor ‘died’) now quits at varying times in the cycle. With a load it went from 5 mins remaining to 0 and I ran an ’empty’ cycle which quit from 8 to 0 yesterday (Full cycle shows 11 mins). It reaches a reasonable speed during the run and the speed selector appears to be controlling ok.
Is this a new control unit or is there some sort of reset I can do? If the former, advice on costs v replacing welcome.
E-Nr WF02864GB/01
September 24, 2007 at 11:07 am #228361nomadPaul
ParticipantDid you use genuine Bosch brushes or patent parts ? I have had a couple of occasions where new patent brushes have caused probs but the genuine Bosch ones work fine .
It might be worth running a couple of ‘spin only’ cycles to help the brushes bed in .
Or you could remove and re-fit the brushes in case they’re not seated properly.
September 24, 2007 at 12:30 pm #228362mikejphillips
ParticipantRe: Bosch Exxcel 1400 Spin cycle problem
Funny you should ask………………….. I needed them on Saturday with Mrs threatening divorce as the washing piled up so I bought ‘look-a-likes’ – HOWEVER, the bizare news is that 2 washes have gone through this am with NORMAL spin, so I guess you may be spot on! I did wonder also if I might have thrown some water around in the process and it has dried out?
Further query now the major panic MIGHT be over (marriage saved…… :rolls: )
1) The little black drain tube produces no more than a few drips when the drum is full – is it prone to blocking and can it be cleared?
2) I removed the pump chamber cap during the work on Saturday and now have a small weep from it, despite a little jointing compound applied. Is there a ‘trick’ to seal it or do I need more Plumber’s Mait?
September 24, 2007 at 2:12 pm #228363Martin
mikejphillips wrote:1) The little black drain tube produces no more than a few drips when the drum is full – is it prone to blocking and can it be cleared?
Not easy due to its length and access to the pump end restricted I’m afraid. 🙁
mikejphillips wrote:2) I removed the pump chamber cap during the work on Saturday and now have a small weep from it, despite a little jointing compound applied. Is there a ‘trick’ to seal it or do I need more Plumber’s Mait?
Blimey!…Just remove, clean and refit the little black rubber gasket and screw it back up finger tight is all that’s required….Plumbers Mate indeed…Good Lord? :rolls:
September 24, 2007 at 3:47 pm #228364mikejphillips
– just remember you are dealing with an amateur here 😀
Did all that first time round but it does not seal properly. I’ll have another go and put the PM out of reach…….
September 25, 2007 at 4:00 pm #228365mikejphillips
Doctor Martin – I am cured of my Plumber’s Mate-it-is 🙂
Sorted and dry as a bone now – thanks again all.
April 28, 2008 at 3:40 pm #228366mikejphillips
I’d like to let you all know how useful again I found this forum. A similar spin problem happened again today and on re-reading the threads here I decided to look at the motor again – (cheap) brushes still fine but commutator heavily carboned. Lacking a ‘comstick’ I cleaned it with emery paper and BINGO!
For the mods and ‘Martin’ – still ‘Plumbers Mate Free’. No cold turkey/withdrawal symptoms. 🙂
