Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch exxcel 1400 trips RCD
- This topic has 5 replies, 2 voices, and was last updated 14 years, 2 months ago by
Gtr_drifter.
January 28, 2012 at 11:33 pm #67632
Gtr_drifter
ParticipantHi all, I have a newborn and been going through loads of washing but machine has just started tripping the RCD!
I have tried running cold washes and it seems to work fine, however on hot washes it seems to trip the RCD. I just tried a hot wash on 90 degrees and tripped again after 10 mins.
Been reading up and potentially a couple of issues with bushes or heating element?
Could anyone recommend my first fix or a number of replacement parts to be on the safe side as I really need it back up and running.
Also with the heating elements is it worth buying a non bosch replacement?
Many thanks
MattJanuary 28, 2012 at 11:35 pm #368036Gtr_drifter
ParticipantRe: Bosch exxcel 1400 trips RCD
Sorry machine is about 5 years old and model number is wae28465GB if that is of any use
January 28, 2012 at 11:37 pm #368037gandh1
please provide full er and fd numbers, located usually on a sticky label on inside of door.
January 29, 2012 at 12:24 am #368038Gtr_drifter
E-nr. WAE28465GB/01 FD 8702600077
January 29, 2012 at 2:56 am #368039gandh1
unlikely to be brushes if its takign 10 mins to trip out, esp if its ok on cold/rise progs, unless theres moisture leaking from somewhere onto the motor or onto terminals or a component, so check that there are no holes around the rubber gasket that could leak onto the electrics or the door lock. so sounds like it may well be the heater circuit. this will include element, ntc, and the pcb module. heater element would be the first place to check tho. a continuity test with a multimeter is unlikely to show anything up however, because your rcd is tripping – you have a current leak to earth.
this means to be sure which part has failed you should insulation test the major components of your bosch. this would normally require an engineer, or an electrician friend. if you dont wish to go down that route then id use a pattern part –
http://shop.ukwhitegoods.co.uk/Washing+ … ement.html
and keep my fingers crossed, because to take a punt with the oem part costing nearly £60 with the p&p is a bit daft!
January 29, 2012 at 11:34 pm #368040Gtr_drifter
Thanks for the quick response. I have pulled it apart and have ordered a copy replacement element. It was filled with grey gunk! Hoping it works!
Cheers
