Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Exxcel 1400 Washing Machine stopped working
- This topic has 14 replies, 4 voices, and was last updated 13 years, 10 months ago by
dhardman.
May 25, 2012 at 12:54 pm #69654
dhardman
ParticipantOur Bosch Exxcel 1400 washing machine has suddenly stopped working.
When we start it, the normal sound of water filling happens but then it just sits there. The timer counts down but nothing happens.
I wondered if the drain pump needed clearing out in case the pump impeller can’t rotate but cannot get the pump cover off. It turns about 30 degrees and then stops and I can’t pull it out. I have removed it before but can’t remember how far it needs to turn.
Any help gratefully received.
thanks
Derrick
May 25, 2012 at 1:28 pm #375501Muv
ParticipantBosch Exxcel 1400 Washing Machine stopped working
Does the water heat up to temperature.?
If not, it’s probably the heater element
May 25, 2012 at 3:39 pm #375502dhardman
ParticipantRe: Bosch Exxcel 1400 Washing Machine stopped working
No, it doesn’t seem to be heating. Is it something I can replace myself?
Many thanks for your help.
Derrick
May 25, 2012 at 3:57 pm #375503dhardman
Sorry – another point. Is it normal that if the element breaks that the machine just sits there and doesn’t just run the cycle ‘cold’?
thanks again
May 25, 2012 at 4:05 pm #375504Muv
Try it on a few different wash settings… See if it’s any different
May 25, 2012 at 4:12 pm #375505dhardman
No, just takes in a bit of water and then sits doing nothing.
May 25, 2012 at 4:31 pm #375506dhardman
Another update!
On another setting it has done something but it’s very odd. It seems to running through the cycle but water is just coming in and pumping out. Doesn’t seem to be any heat and the drum hasn’t moved.
Is it time for a new machine???
May 25, 2012 at 4:33 pm #375507Muv
It could also be the carbon brushes in the motor.. These are attached to either side of the motor, which is, if my memory serves me right,accessible from underneath the machine …
PS. Never work on machine with power on!
May 25, 2012 at 4:38 pm #375508dhardman
OK, well thanks for all your help. Have a good weekend.
Regards
Derrick
May 25, 2012 at 4:39 pm #375509Muv
Does the machine spin ok?
May 25, 2012 at 4:41 pm #375510dhardman
not sure, I’ll go and try it now
May 25, 2012 at 4:48 pm #375511dhardman
Odd again! Started with normal noise of pumping out and showed 11 minutes on the timer. Then after a minute or so the timer dropped to 1 minute.
No spinning happened at all.
Any thoughts?
May 25, 2012 at 5:14 pm #375512Martin
Stop messing and just replace the motor carbon brushes!…..that is your problem all the while!
November 16, 2012 at 6:07 pm #375513feek
Sorry Martin but that doesn’t appear to be the solution either.
I’ve been having the same problems with mine and have replaced the brushes, to no avail – the problems persist.
I’m beginning to suspect it might be something in the control electrics – perhaps not recognizing the signal from the door switch (or similar) since the fault is either intermittent or nothing happens at all, and also the lock is no longer engaging.
November 16, 2012 at 7:43 pm #375514Martin
feek wrote: and also the lock is no longer engaging.
In your case the door must first lock before it will operate therefore I reason that the door interlock is at fault.
