Bosch Exxcel 8 VarioPerfect leaking from door
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Exxcel 8 VarioPerfect leaking from door
  • #94326
    ianj2
    Looking at the rubber seal that abuts the door when it is closed, there is an approx. 5cm section of the rubber ‘flange’ (which presses against the door when closed) missing – it appears to have been torn off, probably when a large bundle of washing has been either stuffed or pulled out. The result is that on any major wash programme, the floor of our utility room gets flooded.
    Is this indeed the likely cause, and if so, what replacement part do I need to order, and can I fit it myself or should I call out an engineer?
    Many thanks in advance.
    #457044
    Re: Bosch Exxcel 8 VarioPerfect leaking from door
    new door seal
    as for fitting it depends on your ability as the front of the machines case has to come off to fit it
    ianj2
    Cheers – thanks Dave
