Bosch Exxcel and Indesit IND125
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Exxcel and Indesit IND125
  • #81844
    Dylscoop
    Hello,
    I have a problem with 2 different dishwashers.
    Dishwasher 1 – Idesit INDF 125
    This is my dishwasher and got a fault last week. When turning on dishwasher it does a prewash (water trickles in) then drains. When the sprayers should start spinning and washing the first anf third light flash simultaneously.
    I checked the drainage which is fine.
    I unplugged the hot water hose from the rear of the dishwasher and turned the tap on to check the pressure, water gushes out the pipe – no problem.
    I have since obtained a second hand dishwasher from a friend, see below.
    Dishwasher 2 – Bosch Exxcel
    I connected up correctly. Put on the dishwasher, dishwasher should full with water but very little comes out. Then when the sprayers should spin the dishwasher remains quiet until it switches to rinse. Then the same process occurs again…. Very little water fills up the washer then drains and no spinning sprayers.
    Seems like a similar problem with both – any ideas??
    #417872
    Re: Bosch Exxcel and Indesit IND125
    Re the Indesit, that error code suggests the appliance is not reaching temperature. Could be heater or control pcb. Not a good idea to plumb this machine to a hot fill TBH.
