Bosch Exxcel Aquastar – E:24 error drain route is clear
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Exxcel Aquastar – E:24 error drain route is clear
  • #82567
    mexmanz
    our Bosch SMS63E12GB/01 Exxcel Aquastar
    Gives the E:24 error after 3 minutes into a cycle.
    I removed the pump and cleaned, plus checked pipe which is clear.
    Running again the same error persists.
    Could the drain motor be faulty or other issue
    many thanks
    Andrew
    #420276
    Re: Bosch Exxcel Aquastar – E:24 error drain route is clear
    in a word yes. on this model they sense the current drawn by the pump motor to detect if its empty. so if the pump is worn it draws more current and fools the electronics
