Bosch exxcel cleaning capability.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch exxcel cleaning capability.
  • #68705
    tinas40
    Hi, as i live on my own i quite often only need to use my dish washer every three -four days but somtimes i notice where the dirty dishes,cups ect have been left around waiting to make up enough to put the dishwasher on, some things might have a bit of mold here and there which bothers me alot and i feal i need to put the dish washer on atleast three times in a row to make sure its all defenately clean, but what i needed to know was would two times be enough as i get through alot of tablets but the the main thing is the water usage, any advise would be very much appreciated,thank you.
    #372509
    Re: Bosch exxcel cleaning capability.
    Use the PRE-RINSE cycle then, that’s precisely what it’s for. 😀
    #372510
    tinas40
    Thanks for your response.
    #372511
    tinas40
    Bosch exxcel water temp advise.
    When using this dish washer does the water reach a hot enough temperature to kill any germs, thank you.
    #372512
    keepitsimple
    There are some domestic dishwasers that have the 80degree plus “sanitisation” cycle that you need to have to comply with regulations for care homes etc., but you don’t normally need it in a domestic situation. Anyway, most bugs won’t grow on a clean surface once it’s dry.
    If you’re still worried, you could always use a chlorine based dishwasher detergent like “bryta” – that should kill off more or less anything. Downside is your kitchen will smell a bit like an old fashioned swimming pool when you open the door 😉
    Don’t think that reputable machine manufacturers or detergent manufacturers would have products on the market that don’t do the job when used as directed.
    #372513
    Re: Bosch exxcel water temp advise.
    tinas40 wrote:When using this dish washer does the water reach a hot enough temperature to kill any germs, thank you.
    In a word yes, but I’m simply answering your question and especially your term of phrase, namely “any”. Even Domestos only kills “99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of household germs” after all said and done.(there’s always a hidden germ someone, with a microscope perhaps, has yet to discover)….
    But seriously, the higher temperatures that a dishwasher attains coupled with the dispersal of detergent will indeed kill best part of all “germs”. By virtue of the fact that most (and I don’t include Ecover in this) contains chlorine based BLEACH…..a known and effective way of dealing with “germs”.
    Bleach based detergents will clear away germs even at a lower temperature. Virtually all dishwashers will reach a temperature of at least 60 degrees in order they be classified as dishwashers in the first place!
    Your Bosch machine is well capable of doing that and most, even the cheaper supermarket branded powders or tablets, will sanitise your crocks and cutlery safe enough to use.
    HTH? 😀
    #372514
    tinas40
    keepitsimple wrote:There are some domestic dishwasers that have the 80degree plus “sanitisation” cycle that you need to have to comply with regulations for care homes etc., but you don’t normally need it in a domestic situation. Anyway, most bugs won’t grow on a clean surface once it’s dry.
    Thank you very much for all the info and advise ,very much appreciated.
    #372515
    tinas40
    HTH? 😀
    Thank you for all the info , much appreciated 🙂 .
