Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch exxcel dishwasher
- This topic has 6 replies, 4 voices, and was last updated 19 years, 7 months ago by
johnnyjazz.
September 18, 2006 at 10:18 pm #20966
johnnyjazz
ParticipantHi everyone.
My dishwasher doesnt seem to finish programme. On the intensive wash (which normaly runs for approx 2hrs) it gets within 1min of finishing and stays like that indefinately. Ive tried other programes and they seem the same. I’ve cleaned the filters inside but thats not helped. Any ideas??September 19, 2006 at 12:10 am #188938Penguin45
ParticipantRe: Bosch exxcel dishwasher
I should think we will be able to offer some advice, but we need the model number – it’s probably engraved into the top edge of the inner door panel. Some of the latest machines have a label down the edge of the door panel.
Sorry, but there is a hoard of Exxel machines, and they’re all slightly different.
Penguin45.September 19, 2006 at 7:19 am #188939Martin
johnnyjazz wrote:it gets within 1min of finishing and stays like that indefinately.
It represents a ‘time-out’ error caused either by a heating element not working or the internal pipework gunged up. If the machine does heat the water up you can discount the former, purchase dishwasher cleaning tablets to help cure the latter. 😉
If the problem persists contact a local independent engineer to look at it for you (see link below)
September 19, 2006 at 8:14 pm #188940Penguin45
I am advised that the machine is SE56EO2GB.
Martin’s comments are valid in relation to the appliance, unless Gegsy wants to add his two h’appence……….. 😀
September 19, 2006 at 8:27 pm #188941gegsy
Nope I think Martin has it covered. Model number is none existent and I have tried different permatations 😀Greg
September 24, 2006 at 10:25 pm #188942johnnyjazz
ParticipantRe: Bosch exxcel dishwasher Stuck on I min
Just to let you know I tried the dishwasher cleaner (3 times) and didnt make any real difference, but as you suspected the internal pipework was pretty clogged up. So I took machine apart and cleaned the internal pipework. The clear plastic housing that the pressure chamber sits on was the worst.
I ran it once more with cleaner and now perfect!! It hasnt worked so well in ages.Can’t thank you guys enough !! 😀
johnnjazz
September 24, 2006 at 10:54 pm #188943Penguin45
Just a word of advice – rinse the heavy deposits off the plates before sticking them in. Rich sauces (bolognaise for instance) are shockers for causing this problems. It’s a washer, not a waste disposal unit 😀 .
Well done,
Penguin45. -
