Bosch exxcel dishwasher – suspected jammed or failed pump
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch exxcel dishwasher – suspected jammed or failed pump
  • #21060
    MartinC
    Hi.
    My Exxcel dishwasher seems to have a jammed pump – it just humms when it should be pumping put…
    Any clues / help available?
    Cheers.
    M
    #189332
    Re: Bosch exxcel dishwasher – suspected jammed or failed pum
    MartinC wrote:Any clues / help available?
    Yes, take the pump cover off (as illustrated in your Instruction Booklet 😉 ) and check if the pump impellor is jammed with something?
    #189333
    MartinC
    OK. Is that the white cover under the filter plate inside the washer?
    #189334
    Yes! 😀 It has one Torx (T20) headed screw holding it in place 😉
    #189335
    MartinC
    Thanks very much Martin. I’ll have a lok.
    Cheers.
    Simon46
    Be careful if it is sharp glass. Difficult to see in the water.
    Regards
    Simon
    #189337
    Simon46 wrote:Regards
    Simon
    How come you’re not at the UKW meet then Simon? Its just up the road from your gaf! 🙂
    #189338
    MartinC
    Ta!
    #189339
    Simon46
    No problem. Was it glass?
    S.
    #189340
    Simon46
    I know wanted to go as well. and no work on. Will travel next year for a day out instead.
    S.
    #189341
    Simon46 wrote:I know wanted to go as well. and no work on. Will travel next year for a day out instead
    Then nip along to the meeting there tomorrow morning, it will be to your advantage. 😉
    #189342
    MartinC
    Simon,
    re:
    S.
    Nope, bleedin’ chicken bone!
    Cheers!
    M
