Hi I have the above type. SP601/51
E-NR.WTA4108GB/03. FD8604000857
So I disconnected the spade connectors from the heater on the drum to change the belt without marking where they went, reconnected and everything seems to be working but I can’t be sure about the low heat when I press the button if it actually is low heat.
So is there anyway to test this out multimeter on spades or anything ?
