The Dishwasher when put on a cycle will, during its cycle stall and the time screen will go blank and then come back on. If I listen it sounds as if relays in the Control Module are trying to instigate a phase in the cycle but failing. It usually happens within the first 20 minutes of a cycle. The stall has happened once or twice when filling up and has caused it to overflow. Today it has happened after 20 minutes when the water is hot and washing the dishes. Other times the cycle will run without problems for days and then reoccur. New Control Module?
Re: Bosch Exxcel SG45E02GB/45 Control Module Fault?
It sounds like it to me. I have an aeg dw that will only heat if you turn off the mains for 60 seconds befor I select a new wash program. open the door in mid was and I lose the heat, Relay problem on the main PCB.
