Bosch Exxcel SGS43A12GB / 27 Not draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Exxcel SGS43A12GB / 27 Not draining
  • #24428
    lord melch
    Hi All,
    Great forum – just what I need I hope.
    Got the above, which is not correctly training.
    Have searched – not bad already for a newbie 😀
    And suspect Impeller blockage, pump or equiv.
    I have unscrewed all the bits I can in the sump area after doing the normal filter removal (I clean them often) and can see the impeller a small “propeller” like thing which turns and it doesn’t seem blocked.
    Is there some other part to be removed somehow to see it fully ?
    I have downloaded the a manual but it doesn’t tell me how to get to the pump/impeller
    Can anyone help further ?
    #202038
    Fairdeal
    Re: Bosch Exxcel SGS43A12GB / 27 Not draining
    Well first of all please switch the dishwasher off before doing anything.
    Do you hear the drain pump running?The drain/waste pipe that connects to the waste trap of the sink is not blocked?
    Take the pipe off and put it in a bucket and then run to see if the water comes out on drain.If not then either something in the drain pump is blocked or it is faulty.
    Regards
    #202039
    lord melch
    Fairdeal,
    I did switch the power off before I tried checking the Impeller.
    I’ll try the drain pump tests tomorrow.
