Re: Bosch Exxcel SGS43E02GB/45
BennGun wrote:How do I gain access to remove the water heater which appears to be located at the bottom of the appliance?
The long and short of it…. with great difficulty.You have to remove pritty much every body pannel and the base. I would advise getting in an engineer. Are you sure it is the heating element as iv also had dry joints on the pcb before .If you really wanna do it yourself then there are loads of posts on the matter.Hope this helps.
