Bosch Exxcel SGS45E02GB – Water overflowing base on startup
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Exxcel SGS45E02GB – Water overflowing base on startup
  • #82959
    qprfcmark
    My Bosch Exxcel dishwasher, when initially being turned on a cycle is filling the entire base and then overflowing out of the machine. Anyone know a cause and a remedy?
    Model: SGS45E02GB
    FD Number: FD8409
    Regards
    Mark
    #421277
    Re: Bosch Exxcel SGS45E02GB – Water overflowing base on star
    did a quick check on your dishwasher
    bosch did a recall on some models of dishwasher when i entered the model and fd number some numbers of you model where affected. there is a number at the end of the Enr /45 or the like
    the /45 models seem to be part of the recall the later ones are not
    go to
    http://www.repairaction.co.uk/
    put in you numbers. if your is covered ring them. its a mod in the timer and you fault will prob be related
    qprfcmark
    Hi Dave,
    Thanks for your reply.
    Model number SGS45E02GB/45 is definitely covered by the recall.
    When you say “its a mod in the timer and you fault will prob be related” how would they be related?
    Regards
    Mark
    #421279
    you fault sounds like a timer fault ie the component that controls the valve is faulty
    the fault with the timer was a bad joint on the heater circuit that goes pop and can blow other components when it fails
    they cant repair the timer so you will get a new one
    get them out to it and see how you go from there
    qprfcmark
    Dave,
    Thanks for your help. Bosch repaired it under the recall. Now working fine.
    Regards
    Mark
    #421281
    bril nice cheap repair for you
