Bosch Exxcel Tumble Drier not heating
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Exxcel Tumble Drier not heating
Viewing 15 posts - 1 through 15 (of 19 total)
  • #23102
    JohnWB
    I have a Bosch Exxcel SP601 / 51 Tumble Dryer which has stopped heating, it starts & runs fine but just doesn’t get warm at any setting. Before I start diving inside, is there anywhere I should look for the problem.
    #197018
    Re: Bosch Exxcel Tumble Drier not heating
    Can you give us the full Enr No of this machine (inside the door) 😉
    #197019
    JohnWB
    Thanks for the reply
    The numbers I copied from the inside of the door are
    SP601/51 and
    51 230220
    I think there were more numbers but I didn’t copy them. If you need them I will have to get them latter
    #197020
    Then its a Bosch I’ve never come across and Bosch don’t recognise the numbers on their site either? 😕
    Is this a UK purchased product? 😕
    #197021
    JohnWB
    Yes, I got it from Comet, I think, about 3 years ago. i will invetigate the number some more
    #197022
    JohnWB
    I now have more numbers – below
    WTA 4108GB/01
    FD 8503000220
    Are these what are required
    #197023
    JohnWB wrote:Are these what are required
    Indeed so, god knows where you got the other numbers from? 😉
    Anyway, possibly the problem is the thermal trip has gone (by the heating element) It may just need the little red button pushing in to reset it maybe?
    If you have ever been guilty of turning the machine off before its automatically completed its cycle?…Then that’s your problem for sure!
    #197024
    JohnWB
    Success – I found the reset button last night as you suggested & pressed it back in and everything now is back to normal.
    Thanks very much
    #197025
    JohnWB
    Is it possable to get a new reset switch (& how much) as I have had to reset it about once a week. I have made sure that the filter & pipework are clean so I guess it is probably the switch on the way out
    #197026
    gegsy
    Martin wrote:If you have ever been guilty of turning the machine off before its automatically completed its cycle?…Then that’s your problem for sure!
    Just to reiterate and eliminate.
    JohnWB
    Greg, thanks for the reply. Since then i have been very careful not to open the door at all until the cycle has definatly finished & it has just happened again. I guess this means the switch is faulty unless you can suggest anything else, if not what is the price of a new switch please.
    #197028
    gegsy
    Ok just to give you more info, the main resons that these trip the safety stat are as follows.
    1/ Overloading ie when loaded there isnt a hand width from top of clothes to top of drum
    2/ Stopping cycle before the final 10 minutes of cool down (Elimated)
    3/ Vent hose kinked,extended or blocked
    4/ Vent hose not extracted and machine pushed back against wall or under unit
    5/ Fluff filter at the front blocked and not regularly cleaned
    6/ In efficient fan operation
    7/ Faulty thermostat/s inc safety thermostat
    Hope that helps
    JohnWB
    Thanks gegsy, in answer to your points
    1- Tumbler never filled up, usualy only about half full
    3 – The vent hose is OK ( only about 18 inches to the outside )
    4 – See above
    5 – Fluff filter cleaned before every cycle
    6 – The fan seens OK & speed hasn’t changed since before this started
    7 – Probably the safety stat as the tumbler does not seem any hotter from the outside of the clothes drying any quicker
    #197030
    gegsy
    It certainly does look like a faulty safety thermostat.
    We have guided the best we can, the ball as they say is in your court 😀
    Regards
    JohnWB
    Thanks for all the advice & help.
    So, does anyone know how much a thermostate is & how I go about getting one
