Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Exxcel Tumble Drier not heating
- This topic has 18 replies, 4 voices, and was last updated 19 years, 4 months ago by
JohnWB.
December 5, 2006 at 8:28 am #23102
JohnWB
ParticipantI have a Bosch Exxcel SP601 / 51 Tumble Dryer which has stopped heating, it starts & runs fine but just doesn’t get warm at any setting. Before I start diving inside, is there anywhere I should look for the problem.
December 5, 2006 at 8:39 am #197018Martin
ParticipantRe: Bosch Exxcel Tumble Drier not heating
Can you give us the full Enr No of this machine (inside the door) 😉
December 5, 2006 at 9:08 am #197019JohnWB
Thanks for the reply
The numbers I copied from the inside of the door areSP601/51 and
51 230220I think there were more numbers but I didn’t copy them. If you need them I will have to get them latter
December 5, 2006 at 9:17 am #197020Martin
Then its a Bosch I’ve never come across and Bosch don’t recognise the numbers on their site either? 😕
Is this a UK purchased product? 😕
December 5, 2006 at 9:30 am #197021JohnWB
Yes, I got it from Comet, I think, about 3 years ago. i will invetigate the number some more
December 5, 2006 at 11:45 am #197022JohnWB
I now have more numbers – below
WTA 4108GB/01
FD 8503000220
Are these what are required
December 5, 2006 at 1:50 pm #197023Martin
JohnWB wrote:Are these what are required
Indeed so, god knows where you got the other numbers from? 😉
Anyway, possibly the problem is the thermal trip has gone (by the heating element) It may just need the little red button pushing in to reset it maybe?
If you have ever been guilty of turning the machine off before its automatically completed its cycle?…Then that’s your problem for sure!
December 6, 2006 at 8:49 am #197024JohnWB
Success – I found the reset button last night as you suggested & pressed it back in and everything now is back to normal.
Thanks very muchJanuary 13, 2007 at 3:23 pm #197025JohnWB
Is it possable to get a new reset switch (& how much) as I have had to reset it about once a week. I have made sure that the filter & pipework are clean so I guess it is probably the switch on the way out
January 13, 2007 at 4:20 pm #197026gegsy
Martin wrote:If you have ever been guilty of turning the machine off before its automatically completed its cycle?…Then that’s your problem for sure!
Just to reiterate and eliminate.
January 19, 2007 at 1:14 pm #197027JohnWB
Greg, thanks for the reply. Since then i have been very careful not to open the door at all until the cycle has definatly finished & it has just happened again. I guess this means the switch is faulty unless you can suggest anything else, if not what is the price of a new switch please.
January 19, 2007 at 1:21 pm #197028gegsy
Ok just to give you more info, the main resons that these trip the safety stat are as follows.
1/ Overloading ie when loaded there isnt a hand width from top of clothes to top of drum
2/ Stopping cycle before the final 10 minutes of cool down (Elimated)
3/ Vent hose kinked,extended or blocked
4/ Vent hose not extracted and machine pushed back against wall or under unit
5/ Fluff filter at the front blocked and not regularly cleaned
6/ In efficient fan operation
7/ Faulty thermostat/s inc safety thermostatHope that helps
January 19, 2007 at 1:32 pm #197029JohnWB
Thanks gegsy, in answer to your points
1- Tumbler never filled up, usualy only about half full
3 – The vent hose is OK ( only about 18 inches to the outside )
4 – See above
5 – Fluff filter cleaned before every cycle
6 – The fan seens OK & speed hasn’t changed since before this started
7 – Probably the safety stat as the tumbler does not seem any hotter from the outside of the clothes drying any quickerJanuary 19, 2007 at 1:35 pm #197030gegsy
It certainly does look like a faulty safety thermostat.
We have guided the best we can, the ball as they say is in your court 😀
RegardsGreg
January 19, 2007 at 2:42 pm #197031JohnWB
Thanks for all the advice & help.
So, does anyone know how much a thermostate is & how I go about getting one -
