Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Exxcel wfo285sgb/01 skips spin
- This topic has 8 replies, 6 voices, and was last updated 18 years, 2 months ago by
nelson.
February 7, 2008 at 8:44 pm #34430
nelson
ParticipantHello, can anyone help with this one, the machine runs through the whole wash. The wash time indicator counts down to 7mins remaining then skips to 1 min remaining without picking up into high speed spin.
I was originally called out because the machine did not spin and still had water in the drum when I tried to drain the machine the pump was not working, so replaced the pump.
However the next wash the machine again did not spin but this time it had drained completely but did as above.
I assumed the module may be faulty so sent it to QER to test but they say no fault found (that said when I spoke to them before hand they had not tested/repaired this particular module before). So I am still not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure if the board is faulty or not and a new one from Bosch is 106 quid (a bit of an expensive guess!!)
Please help. 😕February 7, 2008 at 10:31 pm #242583gegsy
ParticipantRe: Bosch Exxcel wfo285sgb/01 skips spin
May be carbon track over on motor and/or low brushes; worth a try first 😉
Have had two in the past, one was module, other was motor :rolls:Greg
February 8, 2008 at 9:56 am #242584Micky 32
I remember a similiar fault on it’s Siemens sister washing machine. The motor was faulty even though it washed ok etc. If the brushes are ok it’s the motor.
February 10, 2008 at 7:51 pm #242585nelson
Thanks Gegsy & Micky,
I checked the brushes the first time I called out and they were ok. I think I’ll see if I have a motor in the work shop that I can plug in and try before I order a new module.
Thanks again.February 10, 2008 at 7:57 pm #242586Martin
Another thing you could try Nelson is to strip the motor, give the whole unit a darn good flush out with WD40 to clear away all the carbon dust (as Greg mentioned 😉 ). Clean up the commutator with a bedding stick and try it again? If that fails and you reckon the Module checks out OK? Then the motor is a duff’un 🙁
HTH?
February 12, 2008 at 12:42 pm #242587nelson
Cheers martin, I’ll give it a try.
February 15, 2008 at 8:21 pm #242588nelson
😀 Thanks again Martin, Stripped the motor down, dowsed it in WD40 gave my comm stick a bit of welly and hey presto motor back from the dead. Very happy customer 😀 😀 😀
April 13, 2010 at 7:59 am #242589Allsorts
Martin wrote:Another thing you could try Nelson is to strip the motor, give the whole unit a darn good flush out with WD40 to clear away all the carbon dust (as Greg mentioned 😉 ). Clean up the commutator with a bedding stick and try it again? If that fails and you reckon the Module checks out OK? Then the motor is a duff’un 🙁
HTH?
Bedding stick Martin?
George
April 13, 2010 at 10:29 pm #242590leavemetogetonwithit
I think he means a comm stick. The nurse has given him the wrong tablets again.
Mike. -
