Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Exxcel WVD245S3GB/01 bearing change advice
- This topic has 6 replies, 2 voices, and was last updated 11 years, 2 months ago by
wylstar.
January 24, 2015 at 5:31 pm #83861
wylstar
ParticipantHi All,
I have a 5 year old Bosch Exxcel WVD245S3GB/01 washing machine which needs it’s bearings exchange (diagnosed by rust on the rear of the drum below the spider, and a grating noise when rotating).
The questions are has anyone changed the bearings in this model? It looks as though the drum is a complete metal unit. Any advice would be well received.
Thanks!
January 27, 2015 at 10:01 am #424009electrofix
ModeratorRe: Bosch Exxcel WVD245S3GB/01 bearing change advice
the bearings are housed in a metel spider mounted on the back of the drum.
it is possible (but not easy) to remove the spider without removing the drum and withdraw it through the back panel
bosch supply the bearings as a complete spider part no 283726 but at £163 its a bit expensive. you can buy non gen bearing kits very likely from site shop.
if bearings have got to bad it will have damaged drum spider, so strip it and check first
you can see a breakdown at http://www.bosch-home.co.uk/store/spareparts/searchDave
January 31, 2015 at 8:26 am #424010wylstar
ParticipantRe: Bosch Exxcel WVD245S3GB/01 bearing change advice
Thank you Dave. I have a non gen bearing kit, with the x2 bearings and plastic seal. I will give it a go through the small back access panel.
February 1, 2015 at 11:53 pm #424011electrofix
you have got to take a lot more than the access panel
remove the tumble dryer section including the condensor which runs down right hand side
as said its not easy but it is doo able
February 28, 2015 at 11:33 am #424012wylstar
Hi, Thank you for the advice. Do you know if there’s a guide on removing bearings through the back panel? It’s so noisy I need to getting fixed now! Thanks
February 28, 2015 at 2:54 pm #424013electrofix
no as far as i know in fact dont know anyoner else who has done it this way. most engineers remove whole drum
March 2, 2015 at 7:45 am #424014wylstar
Thanks Dave. It’s a sealed metal tub, which is annoying. Do you know if the bearings can still be changed on this? The outer panels of the machine are also one complete panel. Bosch seems to have made this as hard as possible to fix!
I’ve done it a few times on plastic drums that can be split and so know the work this entails! Never come across a metal outer drum though…
