Bosch Exxcell110 WF02264GB
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Exxcell110 WF02264GB
  • #81494
    diyisgreat
    Any ideas how old these machines are ?
    Its my daughters and while it washes and spins ok theres a clunk at the end of the spin and if you rotate the drum it makes a grating noise
    there was loads of black fine grit ? particles coming out of the pump when i first checked and ran it but not on 3 washes since since
    black staining on the rubber drum seal too
    so whether its worth spending time or money on it is a big ???
    It does not seem to be the build quality of my Bosch WFF1201
    which has stainless steel casing around the drum and is twice as heavy
    Having got the back off so that i can better locate the carbon brushes which i am sure must be the problem
    #416820
    Re: Bosch Exxcell110 WF02264GB
    Wow are you covering the forums with one subject here or what?
    The age of any Bosch appliance can be gleaned from the FD number. That’s a 4 digit number tagged on the end of the ENr number (model number). Give us that 4 digit number and we can tell you what year and month it was made. 😉
    Any more questions about a single machine then do please confine them to one thread. 😀
    #416821
    diyisgreat
    Apologies
    I am faced with 2 different Bosch machines and very different models
    its FD 8208 do i guess aug 2008
    #416822
    diyisgreat wrote:its FD 8208 do i guess aug 2008
    That is 2002 (82) August of that year (08) August 2002.
    #416823
    diyisgreat
    sure is nothing like the quality of my Bosch
    #416824
    So, having established these facts and, as your soubriquet suggests, are you still up for a DIY fix on your offsprings machine? Or have you stopped at this point?
    #416825
    diyisgreat
    I would like to fix both machines especially mine as its a hot and cold fill and a superb washer
    Mine the carbon brushes are 2 cm long so as i believe new ones are 3.6cm
    do i need to change them or is it more likely to be dodgy pump even though its propeller spins
    Daughters machine …………how would i establish whether its bra wire or dodgy bearings
    what would have created all the fine black grit that came out of the pump
    #416826
    diyisgreat wrote:Mine the carbon brushes are 2 cm long so as i believe new ones are 3.6cm
    The brushes are just fine. Check the pump Impellor, if there is any sign of lateral movement, and that is very likely judging its age, then the pump needs replacing.
    diyisgreat wrote:Daughters machine …………how would i establish whether its bra wire or dodgy bearings
    Bra wire is so obvious giving a distinct scraping/clicking noise as it rubs against the drum. Plus you can spot the wire through the holes using a torch.
    diyisgreat wrote:what would have created all the fine black grit that came out of the pump
    Detritus lumps from a limescaled heater. Again a torch in the tub in the 6 o’clock position will show the state of the heater.
    #416827
    diyisgreat
    Thank you I will put the brush back
    and get a replacement pump as that would seem likely culprit
    do i need the whole pump unit or can one get just the motor bit ?
    will get torch and have a good look around daughters machine
    are there instructions anywhere on how to remove the wire if thats whats there ….i dont think its bearings because theres no noise when spinning or washing just a clunk when spinning ends and the scraping sound when moving the drum by hand
    #416828
    diyisgreat wrote:do i need the whole pump unit or can one get just the motor bit ?
    Both are available.
    diyisgreat wrote:are there instructions anywhere on how to remove the wire if thats whats there ….
    Removing the sump hose from the tub or by taking the heater out is the usual route.
    #416829
    diyisgreat
    Should be able to manage both of those ….it will be interesting
    #416830
    diyisgreat
    New pump arrived today and Many Thanks Martin Machine now works just great
    Tomorows task to find that bra wire in daughters machine
