Bosch F/F Door Handles
Viewing 15 posts - 1 through 15 (of 15 total)
  • #21460
    Dave_Conway
    Has anyone else had problems with part number 369542 door handles (supplied as a pair) being too “short”.
    I have two customers with the same problem and I just checked against my own model and they’re right, they are about 5cm too short.
    These are the type that “clip” in to the door body and screw on the door side where they wrap around (if that makes sense 😕 )
    TIA
    #190955
    gegsy
    Re: Bosch F/F Door Handles
    Hi Dave
    Not fitted any handles for a while. I know they have changed them slightly because they kept breaking, never had any not fitting.
    Sometimes they feel like they are going to break when after you have offered nib into groove and proceed to bend handle into place 😀
    HTH
    superfix
    Think the all important E-Nr is the key to this.
    As some models are 55cm and others are 60cm wide.
    Just a thought.
    #190957
    gegsy
    I think you onto something there Stu 😉
    Hope you well
    superfix
    Yup not too bad thanks Greg
    Considering I had an LPG gas leak on today 😥
    Never mind lager helps. 😉
    #190959
    Dave_Conway
    Thanks chaps, both customer orders were confirmed Enr’s before ordering.
    I think it may be a supply problem, Greg, order us up a pair would you please 🙂
    Cheers
    #190960
    gegsy
    Dave_Conway wrote: Greg, order us up a pair would you please 🙂
    Done 😉
    gegsy
    Dave those handles are only used in the following appliances according to BSH –
    KGV26310IE/04
    KGV36310/04
    KGV36311/03
    Dave_Conway
    Hmm, I need them for a KGU32121GB/02 which shows 268679 on the diagram, supersedes to 369542 when trying to order.
    Have BSH made a mistake by any chance ? 😉
    #190963
    gegsy
    Yea BSH have trouble with superseded parts when they try and state what fits what.
    Nein 😆
    369542 is correct 8)
    #190964
    Dave_Conway
    gegsy wrote:Nein
    Just the two for now please 😀
    #190965
    gegsy
    On order Dave 1 pk of 2
    Dave_Conway
    Cheers :tup:
    #190967
    What was the p/no for the longer handles?
    Dave_Conway
    369542 was correct in the end 🙂
