BOSCH f/f frozen solid
  • #46273
    Kirk
    KGN34V00GB/02 FD8610, is this one of the units that you can’t change sensor in?
    The freezer is frozen solid I defrosted it but can’t lift it up to slide out,I have never had one this stuck before.
    The sensor at the bottom of freezer compartment is I believe a temp one, nothing to do with defrost?
    Thanks Kirk
    #288771
    helo_75
    theres 3 mods for that
    takes ages to defrost it
    if its fully defrosted. 2 screws and it pulls out easily
    will require heater plate, drain heater and pcb
    #288772
    boselecta
    Bosch advise not to defrost this range with a steamer. Advise customer to defrost for 48hrs before removing evap cover.
    #288773
    Kirk
    Re: BOSCH f/f frozen solid
    Thanks both of you but need part number for pcb does it blow or is it modified ?
    helo_75
    I have removed the 2 screws defrosted it fully but it wont pull out you can see the 2 lugs that need to be lifted out of thier slots but the B….. won’t. budge, I have lifted the unit of the floor trying, it has been repaired before.
    Thanks Kirk
