Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Bosch f/f KSU40640GB/01
- This topic has 3 replies, 2 voices, and was last updated 21 years, 2 months ago by
admin.
February 7, 2005 at 1:59 pm #7812
KeymasterBosch fridge freezer, only 2.7 years old. The freezer’s working fine but suddenly not the fridge. I say suddenly but we have wondered why it’s been a bit noiser than usual recently and why there’s been water at the bottom of the fridge. Our old fridge which lasted 17 years used to have a hole inside at the bottom which was easy to unblock. There doesn’t seem to be any such hole in this one, though there is an outlet pipe at the back with a tray beneath it that’s bone dry. It’s difficult to access but, with wire, I’ve checked that the lower 4 or 5 inches at least are clear. Any ideas? Are the 2 things (fridge not working, water on the floor) related? I’d be very grateful of advice.
February 7, 2005 at 2:33 pm #125287Dave_Conway
ParticipantRe: Bosch f/f KSU40640GB/01
Yes, they are related Paul.
As this is a frost free unit, the cold air is blown up in to the fridge by a fan.
What has happened is there is an excessive ice build up in the freezer behind the rear panel where all the cooling takes place blocking the air flow and some of the excess ice will be melting and running out from underneath.
The first thing to do is empty it then switch the whole thing off for 24 hours with the doors open and allow all the ice to melt. Periodically keep an eye on the tray at the rear you mention and don’t allow it to overflow.
Once all the ice has gone, switch back on and it will be OK, hopefullly cured, if it occurs again there may well be a problem with the defrost section of the unit and will need an engineer to call and rectify, this may take weeks or months to occur though.
See how you get on and let us know 😀
February 7, 2005 at 3:00 pm #125288admin
KeymasterRe: Bosch f/f KSU40640GB/01
Dave, I can’t thank you enough for this, though my wife says: Has Dave got any suggestions about where we put the freezer contents for 24hrs!
Women! I ask you!I’ll let you know how we get on.
Thanks again. PaulFebruary 7, 2005 at 3:14 pm #125289Dave_Conway
Anonymous wrote:Has Dave got any suggestions about where we put the freezer contents for 24hrs
A friendly neighbours freezer ? 😆
