BOSCH F/F will not run in garage
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum BOSCH F/F will not run in garage
  • #36047
    five0ne
    I have a Bosch Fridge Freezer KGV3 120 GB/01 which i moved into my garage and it now refuses to run properly.
    I read on an erlier forum of a similar problem with a Bosch Clasic F/f which is seemingly due to the ambient temp in the winter and runs fine in summer.
    On this model there is a switch inside to overide it and run constantly through the winter.
    I have tried bypassing the control and running constantly myself only for everything in the fridge section to freeze solid too.
    Appart from running this on a timer and guessing on off times Im stumped.
    ANY IDEAS would be apreceated
    #249370
    superfix
    Re: BOSCH F/F will not run in garage
    There is only one answer, get it back inside.
    The s/w you refer to does not override anything, it simply leaves the lamp on half power when the door is closed to try and warm the stat up a bit.
    However if the ambient temp of the garage is very low then the s/w will do diddly squat I’m affraid.
    Please do not bypass anthing as you are only going to cause more problems. Power off please when doing anything :zap:
    #249371
    helo_75
    put some sort of heater in the garage or put it back indoors, its the only answer
    #249372
    THIS ARTICLE will explain.
    Simon46
    Is the bulb working?
    S.
    #249374
    five0ne
    Penguin45 wrote:THIS ARTICLE will explain.
    Thanks for the link all clear now
    Cheers
    Five0ne
    #249375
    gegsy
    Simon46 wrote:Is the bulb working?
    You didn’t say !!
    It is very pertinent to your fault, fiveone.
