bosch kgu3102gb
how do i remove the top contrl panel, to gain access to the control module.everything seems to work ok,except that the temp is stuck on 3 and there seems to be a relay clicking, every now and then behind control panel. any ideas would be much appreciated.
The facia has two screws on the underside, once removed you have to prise off the facia from above using a thin screw driver.
How often does it click?
IIRC the facia module has no relays. :con:
To change the temp setting, you have to hold down the button for a couple of seconds and not stab at it with your finger. It then reverts back to the current temp until the target temp is attained.
