Bosch F/Freezer KGU3201 gb/07
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch F/Freezer KGU3201 gb/07
  • #5841
    bassman
    Has anyone got any info on accessing test menu I think the gas valve is sticking on earlier machines you access test programe to activate the vale on and off wich would cure the valve sticking.
    Many Thanks Ray(Bassman)
    #114112
    wizard
    Re: Bosch F/Freezer KGU3201 gb/07
    Bassman
    If I remember correctly, first switch off the appliance. Then hold down the SUPER button whilst turning on. Keep this held in until the SUPER light has come on and gone off. Release the button and you should have P0 in the right hand display. Now your in test mode. Advance through the test points using the up & down buttons on the right(fridge controls) and activate each test by pressing the SUPER button. I don’t remember which one is the valve activation, but you’ll hear it clonk if it is working. I do remember though that P0 is a full defrost cycle, so I suggest you start with P1.
    Unusual though you don’t get a valve problem on these though, they tend normally only to suffer from ice build up in the rear of the freezer, or intermittent fan motor faults.
    Hope this helps
    Wizard
    #114113
    bassman
    Thanks for the info Wizard this one is frosting up in the fridge so I am hoping it is just a sticky valve.
    Many Thanks for your reply
    Bassman
