Bosch F/FREEZER KGV31464GB/01 Not Cooling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch F/FREEZER KGV31464GB/01 Not Cooling
  • #46932
    a1al
    Hi Everyone
    (FD 8404 Type KG KGW31A )
    Been out to this one earlier today
    When you switch the power on the compressor switches on for 30secs then off 60secs and the middle one of five lights flashes at the same time, continues to do this until you turn the power off.
    Any ideas ??
    Customer is old aged and ill, would like to get this one correct first time.
    a1al
    #291461
    a1al
    Re: Bosch F/FREEZER KGV31464GB/01 Not Cooling
    by the way I meant to say that the power to the compressor is being switched off and on by the control PCB which has connections that are similar to a standard T/Stat setup.
    a1al
    #291462
    a1al
    Hi guys
    Sorry to keep on but does anyone think this could be the control PCB or maybe a sensor.
    a1al
    #291463
    a1al
    Just for the record this turned out to be the Control PCB, which was clicking and switching the compressor off and on in a 30sec cycle.
    The sensor was not the fault as I tried it first.
    PCB Part No 493483 @ £59.55 inc vat & postage (thanks to Chris)
    a1al
