Brushes gone , tried reset so many times I lost count.
Customer did the reset at the weekend, then tried it again, without doing the brushes, would this have spoilt the board.?
Someone mentioned if you try it 3 times & fail, you need to use different finger, is this right?
Cant believe how a simple job can turn into a bl**dy nightmare. 😡
maybe it’s just luck whether u hit button at the right time,or when you lift ya finger off the spin button. you lucky fella!!
didn’t know the door ( open or shut )was connected with reset.
I had exactly the same thing last week. Tried reset about 20 times until I thought I’d try with the other hand before I gave up and it worked first time.
Must be thicker skin on one hand. Who knows!!!
