Bosch HBN7050GB/01
Hi, when we turn off the fan oven, as the fan is slowing down there’s a tapping sound. Turns out the top element screw was loose so the blade was clipping it. I’ve tightened it up but still it comes loose after a few days and the blade taps it when slowing down. Looking at the blade, it’s not totally flat at the back and looks a little warped in places. I don’t know if this is normal (?) but was thinking I should maybe replace the fan blade. I’ve looked online but can’t find a fan blade without buying the fan motor with it – do you know if they are available? What are your thoughts on the (possibly) warped blade and the tapping? Meanwhile I’ve removed the top element screw as the screws at the bottom of the element seem to hold it in place pretty well, for now and I didn’t want the blade making contact with anything. Thanks!
