Bosch fan oven element replacement – HBN7050GB01
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bosch fan oven element replacement – HBN7050GB01
  • #35462
    CarMan7
    How am I going to cook the goose now?!
    The element has blown and I can see it is strapped at the top which is held by a screw behind the fan.
    I could not remove the fan so took 3 more screws out from the plate behind the fan.
    Also lost one element connector behind this plate which I thought would just come free but it doesn’t.
    Am I beyond help?
    Cheers.
    #246581
    CarMan7
    Re: Bosch fan oven element replacement – HBN7050GB01
    OK, feeling a bit happier!
    All sorted – except I still cannot get the fan off it’s shaft ?????
    #246582
    CarMan7 wrote:All sorted – except I still cannot get the fan off it’s shaft ?????
    It’s not unheard of that you have to cut the things off as they virtually weld themselves in place. 😕
    gegsy
    Heres what I do…..
    I remove nut and collar (obviously :rolls:
    Then I squirt a sensible amount of WD40 or equivalent onto the protruding shaft.
    Carefully grab the shaft with pliers (watch the thread) then whilst keeping hold of shaft wiggle the fan vigorously from left to right until its released enough to pull off 😉
    CarMan7
    Yeeeeeehaaaaaaa !!!!!
    Thank you so much
    It’s off now – scared of using enough welly well before.
    All I’ve got to do now is get a new element (hopefully) in the morning.
    Might get my Easter goose after all – I should be so lucky
