Bosch fill and drain on second fill
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch fill and drain on second fill
  • #83950
    llewsserc.1
    🙁 I have a Bosch dishwasher SG145E16GB/28 FD8711.
    On starting machine the check water light comes on approximately one minute after fill begins, then goes off, the first cycle completes but water is exiting via outlet pipe the whole time, although the pump doesn’t seem to be activated and there is adequate, if not more usual water in the machine. The washer blades turn and heater works.
    When this first cycle has finished it drains fine and pump can be heard.
    Second cycle, water check light keeps coming on and off but this time the washer fills and pumps out fills and pumps out, nothing else is happening no washing action and no heater this goes on until I reset and give up.
    Had 2 guys to look.
    #1 twiddled with selection knob said might be aqua stop hose, will fit one anyway if that doesn’t work new PCB. I don’t think so.
    #2 did the same, said it might be pressure switch would have to go away and think about it!! Put on his notes, tried it and seemed to be working OK. Yes it was, because he only ran it for 5 minutes and the real problem begins on second cycle. Can anyone help, please.
    #424332
    Re: Bosch fill and drain on second fill
    The Impellor Jug (part no 00424099) needs replacing.
    #424333
    llewsserc.1
    Thanks Martin.
