Bosch Freezer GUL12444GB/01
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch Freezer GUL12444GB/01
  • #98260
    DougC
    My undercounter Bosch Freezer (GUL12444GB/01) runs continuously. The temperature is down to -21 deg. C. I think that the fault is with the thermostat but I am unable to find a way to remove it. What I’m looking for, on this forum, is help with removing and fitting a new thermostat. Do I have to remove all the insulation or can I just remove the metal angle panel which holds the controls. It appears that I will have to drill out the two rivets on the top.
    Any guidance would be much appreciated.
    Many thanks
    Doug
    #471589
    have you turned the thermostat down to see if it makes a difference ?
    DougC
    Good evening Dave
    Thank you for your response.
    I’m sure I tried that initially but will try again. I need to put the door back on and replace the control panel so I will do it later this evening and try again.
    Let you know tomorrow.
    Thank you
    Doug
    #471591
    DougC
    Good morning Dave
    I’ve replaced all the bits and with an empty freezer I get the following results:
    Time Date Temp.Running?
    20:00 29/8 +22.5 Yes
    03:30 30/8 -20.2 No
    08:00 30/8 -18.2 No
    09:35 30/8 ?? Yes just started
    10:15 30/8 -20.4 Yes
    The thermostat is set on 1 normally it is between 3 and 4.
    It would appear that the thermostat will switch on and off. Could it still be faulty or is there something more serious?
    Thank you in advance
    Doug
    #471592
    cant be more serious otherwise it would not get down to those temp
    if it was only getting to -10 then you would have problems
    in fact those temps above and the fact it is turning on and off, Is there really a problem ?
    DougC
    Hi Dave
    The freezer is still running at 11:55 this morning, the temperature is -23.6 deg. C. When I open the door there is a whishing sound for a second or so.Sounds like air or gas escaping!
    Best wishes
    Doug
    #471594
    well anything escaping cant be anything to do with the refrigeration as it would have stopped freezing by now
    as long as its going on and off then its probably ok. you just might have got to it during an on phase. to know whats going on you would have to check it every 15 mins or so over a few hours
    DougC
    Hi Dave
    The thermostat was originally set between 3 and 4 before it started running all the time.It ran continuosly for about six weeks so we emptied it and left it switched off while we went away for a week. Do you think leaving it off would make a difference?
    At 13:21 it switched off and the temperature was – 23.3 it came back on at 13:45 and the temperature was -16.6. It’s still running with temperature of -23.1
    It is currently in the conservatory (somewhere to work on it) It is a little warm in there! Could the seals be a problem since the temperature went up 6.7 degrees in 24 minutes?
    Doug
    #471596
    turning it off would not have made any difference it sounds like the stat is out of calibration. so the high setting is lower than the unit can attain
    if the operating temp is ok set at 1 and the temp is ok then it should work with no problems
    DougC
    Hi Dave
    Thank you.
    What should the working temperature be?
    If the thermostat continues to go further out of calibration, how do I fit a new one?
    Doug
    #471598
    anything below -18 should be ok
    it looks like an old fashioned hydraulic stat which has a capillary tube. one you access the stat some of them have a tube you push the tube down others have a duct where the tube goes and it bolts on to the evaporator
    don’t know with this model and the part listings and diagrams don’t give you any idea
    DougC
    Thank you Dave
    I will just put it back and see how it goes with a full load.
    Thank you for your help
    Best wishes
    Doug
