We have a Bosch KGU32161GB/02. The freezer temperature goes from -19 through to -32 and then slowly back down again and then starts its journey upwards again (or should that be down for -32!). I was told that the circuit board had gone wrong. Do you think this is correct? I couldn’t find a circuit board on Bosch spare parts website. Also the fridge, although it says its at 4c doesn’t seem to be cold enough either. The fridge freezer is only about 4 years old. Any advice much appreciated.
Re: Bosch freezer temperature -19 to -32 all the time
Turn the appliance off for at least 24 hours, have lots of old towels at the back and front of m/c to catch the water.
If the problem re-occurs then I’m affraid it’s engineer time as you may have a problem with the defrost program, and these are complicated m/c’s not for the DIY’er.
Thanks for the tips. Did switch off for 24 hours and thought it had worked for the freezer as it stayed at -19 for a while. But now going back to -26 and down again. Also fridge is now definitely on the blink going from 8 to 16 degrees. Is it time to get a Bosch engineer do you think? Or is there anything else I can check? 😕
