Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Bosch fridge freezer bulb problem
- This topic has 8 replies, 2 voices, and was last updated 7 years, 1 month ago by
Katcher.
February 9, 2019 at 2:11 pm #95460
Katcher
ParticipantWe have a American style fridge freezer. The model number is KAN62V41GB/03
both bulbs have fused in the fridge.
I ordered 2 bulbs from a seller on eBay. The bulbs wouldn’t work, it looks like each bulb is slightly shorter than the original and so the connection isn’t made. So I sent them back for a refund.
I then emailed espares and gave them the model number and they send me the following link (see link below).
I even phoned espares and gave them the model number as the web page on the espares website wouldn’t recognise my Model number to confirm compatibility of the part. But espares confirmed to me that the bulb would fit.
the 2 bulbs from espares came today and the same problem again. The bulbs appear slightly shorter than the original.
Can someone kindly point me to the correct part?
February 9, 2019 at 2:35 pm #460440electrofix
Moderatoraccording to Bosch this is the correct lamp
https://shop.ukwhitegoods.co.uk/appliance-bulbs/00612235-genuine-daylight-fridge-bulb
part no 00612235
February 9, 2019 at 2:46 pm #460441electrofix
Moderatorwhat worries me here is the lamps you were supplied with despite not being the genuine part should however work with no problems. when you say the lamps are short, if that means the glass part then this should not affect things as the lamp has a standard E14 fitting
when the old lamps went faulty did the filament just break or was there evidence of them going pop. I ask this because if a lamp goes with a pop its likely that the control board may have been damaged
February 9, 2019 at 3:23 pm #460442Katcher
Participantelectrofix wrote:what worries me here is the lamps you were supplied with despite not being the genuine part should however work with no problems. when you say the lamps are short, if that means the glass part then this should not affect things as the lamp has a standard E14 fitting
If you hold the original bulb against the espares bulb, the original bulb is slightly longer in height.
February 9, 2019 at 5:26 pm #460443electrofix
Moderatorthe only thing that matters for connection is the screw end. ignore the glass envelope or the overall length. If you look at just the screw bit is it the same ?
February 15, 2019 at 8:36 am #460444Katcher
Participantelectrofix wrote:the only thing that matters for connection is the screw end. ignore the glass envelope or the overall length. If you look at just the screw bit is it the same ?
https://www.bosch-home.co.uk/store/00612235#/Tabs=section-reviews/
ordered the above part from Bosch, I’ve not tried it as yet as I had to collect from the local Royal Mail sorting office, I’ll try tonight.
the silver screw bits and the black nipple at each end do look the same. It’s just that the blue coloured end on one bulb (the fused one) is just a touch longer than the bulb I’ve just received from Bosch.
im not confident it will work, unless of course both bulb sockets inside the fridge need repairing.
February 15, 2019 at 8:41 am #460445Katcher
I didn’t realise the fridge had 2 bulbs, so 1 was fused perhaps 12-18 months ago and I never realised. The 2nd bulb fused about 12 days ago. Don’t recall a popping sound. Just opened the fridge and darkness. Both fused bulbs were intact.
when I say the bulb is short, I mean the blue coloured glass part
https://www.4bosch.co.uk/product.pl?pid=2284084
in this review, sounds like one person had the same problem, and had a Philips bulb fitted to solve his problem
February 15, 2019 at 9:05 am #460446electrofix
Moderatorwell if its the solder nipple on the bottom of the lamp its easy to check with the old one
this E14 fitting is a fairly common in todays lamps have you got another fitting around the house you could check the lamp
February 15, 2019 at 8:58 pm #460447Katcher
ParticipantTried the Bosch ordered bulbs tonight and they both worked. One bulb when screwed in came on straight away, the other didn’t and after fiddling with it, it came on.
