Bosch fridge freezer – ENr KGV3 120GB/01
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch fridge freezer – ENr KGV3 120GB/01
  • #5853
    Dales-Electronic
    Has anyone got the part number for the thermistor for this machine and where I might get hold of one. Cheers – Ian.
    #114152
    Re: Bosch fridge freezer – ENr KGV3 120GB/01
    hiya mate , hows it dangling?
    In answer to your question try the website http://www.bshappliancecare.com/bosch/
    where the quickfinder option is fantastic and very user friendly…all the parts and prices from bsh with diagrams too!
    regards
    kevin
    #114153
    Dales-Electronic
    Thanks Kevin – Already had a look but can’t find it listed. Maybe this is one of those items that needs a man that can!! Martin where are you??
    #114154
    sparkey
    It appears that this model has non-replacable foamed in NTC sensors, will confirm tomorrow when I have access to my Quickfinder technical laptop
    #114155
    wizard
    The most common fault on these particular machines is the failure of the fridge NTC, which is a non replaceable foamed in one. However, if this is the one that is causing the problem Bosch have recently released a modification kit which takes this NTC out of circuit & makes the electronics run in an emergency mode. I’ve fitted a couple of these now with great success – Saves sending the appliance to the local fridge mountain !
    Kit is available from BSH Appliance Care 08705 543210, part no. 491415 & if I remember correctly it’s about £12.
    Wizard
    #114156
    sparkey
    Hi Ian,
    As Wizard say’s if appliance cools down then switches off on defrost then ‘forgets’ to switch back on the fault is the evaporator sensor which I can confirm is ‘foamed in’. 🙁
    The mod. kit is not necassary to complete repair, simply identify sensor wires at four pin module plug, locate terminals 1 and 3 cut off sensor leads leaving about 2ins lead still connected onto plug, join them together and insulate, tape up now unused sensor lead and push inside plastic frame out of way. 😀
    regards Sparky
    #114157
    Dales-Electronic
    Thanks Sparky, I will try that tomorrow.
