Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Bosch fridge/freezer Exxcel KGU31125GB/01 Frost free
- This topic has 9 replies, 2 voices, and was last updated 3 years, 11 months ago by
martfoxy.
April 17, 2022 at 12:33 pm #100747
martfoxy
ParticipantThe warning light has come on – on this fridge/freezer (Bosch KGU31125GB/01) (I presume for the freezer part). The freezer is cold but not as cold as normal. It is set to -18C and the fridge to +4C. I dusted down the grill on the back and checked the door seals (seem ok). Is there anything else I can check – I have a multimeter.
Thank you
April 17, 2022 at 12:55 pm #482045electrofix
Moderatorit may be set to -18 but unless you have a thermometer you wont know
April 17, 2022 at 1:06 pm #482046martfoxy
ParticipantMeasured the temperature in the freezer and its about -7C.
April 17, 2022 at 1:35 pm #482047electrofix
Moderatorwell thats way too high to be safe. At those temps its a one star freezer which is good for a week max storage
check the fan is running in the freezer
it could be iced up at the back so would need a total defrost which is plug out and doors open for 2 days
April 17, 2022 at 2:37 pm #482048martfoxy
ParticipantThanks for your reply.
Bit stuck about defrosting for 2 days as haven’t got access to another freezer.
I can’t see a fan in the freezer – just one in the fridge which does come on sometimes.
Here is a link to the parts for this model: Online help, spare parts and accessories | Bosch UK (bosch-home.co.uk)
ThanksApril 17, 2022 at 3:01 pm #482049electrofix
Moderatorfreezer fan is item 0310
the evaporater item 0303 can get full of ice, somtimes jamming the fan which means cold air cant circulate
April 17, 2022 at 5:25 pm #482050martfoxy
ParticipantI turned it on with the fan exposed and didn’t seem to be turning. I unplugged and took the connector fans off and tested it seems to be open circuit. A new fan from Bosch is £198!
April 17, 2022 at 5:40 pm #482051electrofix
Moderatorfan only runs with the door closed otherwise it would blow cold air out
you may not get a reading with a meter as some have electronic boards inside
fan on ebay for £60
April 19, 2022 at 12:46 pm #482052martfoxy
ParticipantThanks for your help on this.
I tested the fan by putting a magnet up to the switch at the front and it works.
I noticed there is a lot of ice under the coils so I defrosted it as suggested.
I have powered up again to see it gets down to -18C.April 20, 2022 at 10:16 am #482053martfoxy
ParticipantMeasured the temperature inside the freezer its now -18C (and the warning light is off) – so the defrost worked. Thanks.
