Bosch Fridge/Freezer, Fridge 2 warm
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch Fridge/Freezer, Fridge 2 warm
  • #24899
    rosie-lee
    Hi, I’m new to your site, came across it whilst trying to find out why my Bosch fridge freezer Model KGV3120 ( approx 5 years old ) is giving me probs. Freezer works fine but Fridge is not cooling properly, only does so when i switch it off and then back on again. I suspect some sort of thermostat, but Hey what do I know ? thats why i’m here. Any ideas anyone ?? Thanks 😕
    #203729
    Fairdeal
    Re: Bosch Fridge/Freezer, Fridge 2 warm
    Read the following article, you will find it very usefull;
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=108
    It could be ice built up in the freezer so you may have to switch it off for few hours and let the ice in the freezer compart(you may not see the ice).
    Let us know what happens
    Regards
    #203730
    rosie-lee
    Thank you very much for your reply, i have defrosted the fridge/freezer this evening and will check the fridge temperature in the morning. I will let you know how i’ve got on. Also thanks for the link which makes interesting reading but i’m not sure mine is a ” frost free ” model, it looks like conventional fridge/freezer with cooling elements in the freezer and the usual compressor and cooling pipework on the back, thanks, i appreciate your help .
    #203731
    clivejameson
    Yours is definitely not a frost free model in which case defrosting the freezer will not cure the fault.
    Does the compressor run all the time? If it does then it’s serious (coolant leak, weak/worn compressor)
    If the compressor switches on and off periodically it may be the thermostat which is altogether much easier (and cheaper) to rectify.
    #203732
    rosie-lee
    Hi, dissapointing new this morning after last nights defrost, freezer and fridge cooled ok initially and then this morning freezer OK but fridge not cooling again. so i switched it off and then on again and compressor starts ok but it seems as though a thermostat on the fridge is not working ! Can you tell me where this is and where to get a replacement. Many thanks.
    #203733
    No thermostat as such on this one, Rosie. Electronic control board, therefore thermistor sensors as well.
    Time for some pro help – tricky to diagnose properly like this.
    rosie-lee
    Oh Dear, sounds expensive !! Might be aswell to buy a new model though very dissapointed with Bosch if this is the case. Don’t think i’ll buy another Bosch. But please reply if you think you may be able to help. Thanks.
    #203735
    helo_75
    please, try not to be so hasty
    bosch are probably one of the best fridge freezers on the market.
    5yrs seems to be average lifespan to be fair, although bosch tend to last longer
    dont be dissapointed with bosch and buy hotpoint/indesit stuff!!!!
    if you do, then youll know wot true disapointment is
    sounds like a thermistor problem to be fair, well, its either that or the pcb as penguin advised
    as always, its dificult to advise exactly over the forum, butin this case, it might well not be an over expensive repair, and proffssional advice would be called for
    hope this helps
    #203736
    rosie-lee
    Thanks 4 ur advice helo_75, I’ll not give up just yet, i’ll try a local refridgeration engineer for an estimate and not give up on Bosch yet, maybe i’m expecting it to last forever but 5 years only seems like 2 or 3 !!! 🙂
    #203737
    rosie-lee
    I have’nt given in yet, had the thing to pieces this evening, after listening to your advice suspect it may be the pcb as i tested the resistance of the thermistors and results were approx 11K for fridge at approx 15 C and approx 17K for freezer at -1C or thereabouts ( god knows where they are located though ? ), I really dont know alot more than this though so by proccess of elimination i suspect the pcb. Somebody please tell me if that sounds about right and if so where can a buy a pcb from ? Any ideas on how much they are ? Thanks again.
    #203738
    rosie-lee
    Problem now fixed 🙂 Faulty thermistor bypassed and now all OK. Thanks for your help everyone. 🙂
    #203739
    Smallwoodenone
    Coincidentally, I have just experienced the same problem with the same model !
    HOw much did the repair cost ?
    #203740
    rosie-lee
    The repair was free as i fixed it myself but wouldn’t recommend it unless you are competent with circuit boards / electrics. All the info was found on this site so if you search for Bosch info you will find the cure. Good luck. 😉
    #203741
    helo_75
    u by passed the thermistor and its working ok?
    interesting, to say the least
